Photonics
Photonics
About target phase and calculate RCP to LCP conversion efficiency of metasurface
    • Dang Du Nguyen
      How we can generate target phase and calculate right circular polarization (RCP) to left circular polarization (LCP) conversion efficiency of metasurface ?
      I am trying to reproduce the simulation data in this paper below, for example Figure 2, 4, 5. But I could not know where I can start from to simulate ? (I am a beginner !!!)
      They use this structure to simulate, and is that table S2 come from phase calculation ? that why they can build up the metalen based on the nanostructure.
      https://www.degruyter.com/document/doi/10.1515/nanoph-2018-0204/html (This is the paper that I will reproduce the simulation data.)
      I am looking forward to hearing from you soon :)
      Thank you so much !!!
    • Guilin Sun
      There are several steps to design a metalens:
      1: understand how does it work
      2: know what the lens performace, eg a spherical or a cylinder wavefront
      3: design the unit cell to create a phase change from 0 to pi or -pi to pi
      4: test the whole metalens.
      Please refer this article: https://optics.ansys.com/hc/en-us/articles/360042097313-Metalens
      Duplicating other's results can be very challenge in many cases, since you may not be able to have all their design and simulation information. Please refer this post:
      Ansys Insight: Why my simulation result is different from published paper or experiment?
      Since you are a bignner, please do this step by step, and write new posts for each question. I am sure you can quickly do your own design soon.
    • Dang Du Nguyen
      Thank you Guilin Sun :)), I appreciate your help.
      I will start the design based on your recommendation.
