April 5, 2022 at 2:12 pm
Jiayi
SubscriberI'm using the spaceclaim script to model a feature and something weird is happening. In the sketch coordinate system of the sub-plane I created, different data will make the directions of x and y reversed. I have looked for a variety of ways to define the sketch coordinate system, but still cannot fix the coordinate system. Are there any parameters in the function that can fix the orientation of the sketch coordinate system?
April 7, 2022 at 2:22 pmNaresh Patre
Can you embed some snapshots of the script and the geometry that you are trying to model?
- Naresh Patre
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2146
1357
1150
462
