June 13, 2022 at 2:54 am
longt8
SubscriberHello,
I am going to use Constrained_Tired_Nodes_Failure to simulate the solid 3D element failure. In the dynamore example(https://www.dynaexamples.com/introduction/examples-manual/contact/tied-1), I see the elements are not connected naturally. The element nodes are discretized first and connected using Constrained_Tired_Nodes_Failure.
Would you give me some instructions to discrete the node connection and give some small space between them as the picture below so that I can reconnect by this constrain_tired_nodes_failure?
Thank you!
Teng
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3638
2502
1729
1224
578
