LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
About the d3plot files not fully generated
    • Rong Jin
      There is an issue of the Ls-dyna SPH simulation. When I use the solver on my University HPC to do a SPH simulation, the d3plot cannot fully generated. The total set steps are about 102 d3plots for normal termination, while after generating about 80 d3plots, the solver got stuck and the task reported an error after running out of time. However, when I use the LS-Run on my Windows desktop, the job could end normally. The solver version on the HPC is R 10.1 and the local solver on my desktop is R 13.0. I’m not sure whether the solver version led to that issue.
      The message file for the failed job:
       Date: 09/15/2023      Time: 15:40:54
           ___________________________________________________
           |  Livermore  Software  Technology  Corporation   |
           |  7374 Las Positas Road                          |
           |  Livermore, CA 94551                            |
           |  Tel: (925) 449-2500  Fax: (925) 449-2507       |
           |  www.lstc.com                                   |
           |_________________________________________________|
           |  LS-DYNA, A Program for Nonlinear Dynamic       |
           |  Analysis of Structures in Three Dimensions     |
           |  Version : smp s R10.1.0   Date: 01/12/2018     |
           |  Revision: 123264          Time: 16:34:46       |
           |  Features enabled in this version:              |
           |    Shared Memory Parallel                       |
           |    ANSYS Database format                        |
           |    ANSYS License (ANSYS192)                     |
           |  Licensed to:                                   |
           |  Platform   : Xeon64 System                     |
           |  OS Level   : Linux 2.6.18 uum                  |
           |  Compiler   : Intel Fortran Compiler 16.0 SSE2  |
           |  Hostname   : cascade051                        |
           |  Precision  : Single precision (I4R4)           |
           |  SVN Version: 123300                            |
           |  Unauthorized use infringes LSTC copyrights     |
       Input file: Run.k
       The native file format       : 32-bit small endian
       Memory size from command line:  1000000000
       ********  notice  ********  notice  ********  notice  ********
       * This is the LS-DYNA Finite Element code.                   *
       * Neither LSTC nor the authors assume any responsibility for *
       * the validity, accuracy, or applicability of any results    *
       * obtained from this system. Users must verify their own     *
       * results.                                                   *
       * LSTC endeavors to make the LS-DYNA code as complete,       *
       * accurate and easy to use as possible.                      *
       * Suggestions and comments are welcomed.  Please report any  *
       * errors encountered in either the documentation or results  *
       * immediately to LSTC through your site focus.               *
       * Copyright (C) 1990-2018                                    *
       * by Livermore Software Technology Corp. (LSTC)              *
       * All rights reserved                                        *
      LSTC Environment Variables:
      LSTC_LICENSE=ansys
       Beginning of keyword reader                                   09/15/23 15:40:54
       expanding   memory to  1000000000 d         600 beginning of keyword reader
       contracting memory to       21002 d         600
       expanding   memory to       81130 d     2212719
       expanding   memory to      111130 d     2212719
       expanding   memory to      171130 d     2212719
       expanding   memory to      191576 d     2212719
       expanding   memory to      212264 d     2212719
       expanding   memory to      233264 d     2212719
       Open include file: SPH_Ball_15x15x15.k
       expanding   memory to      255440 d     2212719
       Open include file: SPH_Plate_90x90x30.k
       expanding   memory to      277440 d     2212719
       expanding   memory to      299040 d     2212719
       expanding   memory to      320640 d     2212719
       expanding   memory to      342240 d     2212719
       expanding   memory to      363840 d     2212719
       expanding   memory to      385440 d     2212719
       expanding   memory to      407040 d     2212719
       expanding   memory to      428640 d     2212719
       expanding   memory to      450240 d     2212719
       expanding   memory to      471840 d     2212719
       expanding   memory to      493440 d     2212719
       expanding   memory to      515040 d     2212719
       expanding   memory to      536640 d     2212719
       expanding   memory to      558240 d     2212719
       expanding   memory to      579840 d     2212719
       expanding   memory to      601440 d     2212719
       expanding   memory to      623040 d     2212719
       expanding   memory to      644640 d     2212719
       expanding   memory to      666240 d     2212719
       expanding   memory to      687840 d     2212719
       expanding   memory to      709440 d     2212719
       expanding   memory to      731040 d     2212719
       expanding   memory to      752640 d     2212719
       expanding   memory to      774240 d     2212719
       expanding   memory to      795840 d     2212719
       expanding   memory to      817440 d     2212719
       expanding   memory to      839040 d     2212719
       expanding   memory to      860640 d     2212719
       expanding   memory to      882240 d     2212719
       expanding   memory to      903840 d     2212719
       expanding   memory to      925440 d     2212719
       expanding   memory to      947040 d     2212719
       expanding   memory to      968640 d     2212719
       expanding   memory to      990240 d     2212719
       expanding   memory to     1011840 d     2212719
       expanding   memory to     1033440 d     2212719
       expanding   memory to     1055040 d     2212719
       expanding   memory to     1076640 d     2212719
       expanding   memory to     1098240 d     2212719
       expanding   memory to     1119840 d     2212719
       expanding   memory to     1141440 d     2212719
       expanding   memory to     1163040 d     2212719
       expanding   memory to     1184640 d     2212719
       expanding   memory to     1206240 d     2212719
       expanding   memory to     1227840 d     2212719
       expanding   memory to     1249440 d     2212719
       expanding   memory to     1271040 d     2212719
       expanding   memory to     1292640 d     2212719
       expanding   memory to     1314240 d     2212719
       expanding   memory to     1335840 d     2212719
       expanding   memory to     1357440 d     2212719
       expanding   memory to     1379040 d     2212719
       expanding   memory to     1400640 d     2212719
       expanding   memory to     1422240 d     2212719
       expanding   memory to     1443840 d     2212719
       expanding   memory to     1465440 d     2212719
       expanding   memory to     1487040 d     2212719
       expanding   memory to     1508640 d     2212719
       expanding   memory to     1530240 d     2212719
       expanding   memory to     1551840 d     2212719
       expanding   memory to     1573440 d     2212719
       expanding   memory to     1595040 d     2212719
       expanding   memory to     1616640 d     2212719
       expanding   memory to     1638240 d     2212719
       expanding   memory to     1659840 d     2212719
       expanding   memory to     1681440 d     2212719
       expanding   memory to     1703040 d     2212719
       Open include file: MatFile_Y5_PA.k
       expanding   memory to     1732040 d     2212719
       expanding   memory to     1815114 d     2212719
       expanding   memory to     1896712 d     2212719
       expanding   memory to     1978310 d     2212719
       expanding   memory to     2059908 d     2212719
       expanding   memory to     2141506 d     2212719
       expanding   memory to     2223104 d     2212719
       expanding   memory to     2639248 d     2212719
       expanding   memory to     2884040 d     2212719
       expanding   memory to     3128832 d     2212719
       expanding   memory to     5821534 d     2212719
       expanding   memory to     6066326 d     2212719
       expanding   memory to     6311118 d     2212719
       expanding   memory to     6737848 d     2212725
       expanding   memory to     7153992 d     2212725
       Memory required to process keyword     :     7153992
       contracting memory to           1 d     2212725 end of keyword reader
       LS-DYNA will perform a structural only analysis
       Y5_PA_HV
                               ls-dyna smp.123264 s           date 01/12/2018
       expanding   memory to        2767 d         666 material, node and element data
       expanding   memory to        2845 d         668 mat add general damage 0
       expanding   memory to        2865 d         668 material added airbag porosity leakage
       expanding   memory to        2871 d         668 material properties
       expanding   memory to        2968 d      246487 element data for composite material
       expanding   memory to        2982 d     8323567 gradient of damage data
       expanding   memory to        3057 d     8323569 user control for contact interfaces
       contracting memory to        3039 d     8323569 thermal expansion 0
       expanding   memory to      247830 d     8323569 temp index array for node sorting
       contracting memory to        3039 d     8568364 for boundary cond. vectorization
       contracting memory to        3039 d     9057946 arbitrary element numbering input
       contracting memory to        3039 d     9057946 thick shell int. pt. strain
       expanding   memory to        3597 d    10281906 process element material data
       expanding   memory to        5598 d    10281904 load curve data
       contracting memory to        3604 d    10281904 user_define_loading_set
       expanding   memory to        3804 d    10281904 regularize time history data
       expanding   memory to        3808 d    10281904 *DEFINE_ELEMENT_DEATH
       contracting memory to        3808 d    10281904 rigidwall definitions
       expanding   memory to      248600 d    10281904 nodal constraint sets
       contracting memory to        3998 d    10281904 contact interfaces
       expanding   memory to      494580 d    10281904 implicit contact 1
       contracting memory to        4998 d    10282008 contact segment data 1
       expanding   memory to     1228953 d    10282008 contact segment data 3
       contracting memory to        3998 d    14493971 contact definition
       expanding   memory to      983386 d    14493971 rigid body
       contracting memory to        4638 d    14493995 contact friction
       expanding   memory to        4669 d    14493995 joints
       expanding   memory to    35744235 d    14494595 SPH elements
       expanding   memory to    36233817 d    14494595 discrete element
       contracting memory to    36233817 d    14739710 accelerometers
       expanding   memory to    36233917 d    14739710 rigid bodies for disp. termination
       contracting memory to    36233917 d    15474083 transformation to move nodes
       expanding   memory to    36233919 d    14739761 mat add cohesive 0
       contracting memory to    36233919 d    14739761 sensor_control for curve
       expanding   memory to    36233921 d    14739761 flexible body 2
       contracting memory to    36233921 d    14739761 implicit joints
       S t o r a g e   a l l o c a t i o n
       Memory required to begin solution      :      37M
       Additional dynamically allocated memory:      15M
                                         Total:      51M
             1 t 0.0000E+00 dt 1.10E-12 flush i/o buffers            09/15/23 15:41:07
             1 t 0.0000E+00 dt 1.10E-12 write d3plot file            09/15/23 15:41:07
            96 t 9.4113E-08 dt 9.41E-09 write d3plot file            09/15/23 15:41:58
           103 t 1.8341E-07 dt 1.83E-08 write d3plot file            09/15/23 15:42:01
           108 t 2.9539E-07 dt 2.95E-08 write d3plot file            09/15/23 15:42:04
           111 t 3.8597E-07 dt 3.01E-08 write d3plot file            09/15/23 15:42:06
           114 t 4.8081E-07 dt 3.33E-08 write d3plot file            09/15/23 15:42:08
           117 t 5.8049E-07 dt 3.26E-08 write d3plot file            09/15/23 15:42:09
           120 t 6.7355E-07 dt 3.07E-08 write d3plot file            09/15/23 15:42:11
           123 t 7.7186E-07 dt 3.20E-08 write d3plot file            09/15/23 15:42:13
           126 t 8.6933E-07 dt 3.56E-08 write d3plot file            09/15/23 15:42:15
           129 t 9.7590E-07 dt 3.48E-08 write d3plot file            09/15/23 15:42:17
           132 t 1.0795E-06 dt 3.37E-08 write d3plot file            09/15/23 15:42:18
           135 t 1.1817E-06 dt 3.54E-08 write d3plot file            09/15/23 15:42:20
           138 t 1.2895E-06 dt 3.64E-08 write d3plot file            09/15/23 15:42:22
           141 t 1.3997E-06 dt 3.62E-08 write d3plot file            09/15/23 15:42:24
           143 t 1.4717E-06 dt 3.61E-08 write d3plot file            09/15/23 15:42:25
           146 t 1.5796E-06 dt 3.49E-08 write d3plot file            09/15/23 15:42:27
           149 t 1.6842E-06 dt 3.46E-08 write d3plot file            09/15/23 15:42:29
           152 t 1.7902E-06 dt 3.61E-08 write d3plot file            09/15/23 15:42:31
       *** Warning 40042 (SOL+42)
           Part ID = 5000001 plasticity algorithm did not converge for MAT15
           time = 1.8989E-06, ncycle = 154
           155 t 1.8989E-06 dt 3.67E-08 write d3plot file            09/15/23 15:42:33
           time = 1.9356E-06, ncycle = 155
           157 t 1.9725E-06 dt 3.76E-08 write d3plot file            09/15/23 15:42:34
           160 t 2.0818E-06 dt 3.59E-08 write d3plot file            09/15/23 15:42:36
           163 t 2.1906E-06 dt 3.85E-08 write d3plot file            09/15/23 15:42:38
           165 t 2.2671E-06 dt 3.78E-08 write d3plot file            09/15/23 15:42:40
           168 t 2.3827E-06 dt 3.76E-08 write d3plot file            09/15/23 15:42:41
           171 t 2.4913E-06 dt 3.90E-08 write d3plot file            09/15/23 15:42:43
           173 t 2.5694E-06 dt 3.79E-08 write d3plot file            09/15/23 15:42:45
           176 t 2.6795E-06 dt 3.31E-08 write d3plot file            09/15/23 15:42:47
           179 t 2.7811E-06 dt 3.62E-08 write d3plot file            09/15/23 15:42:49
           182 t 2.8865E-06 dt 3.85E-08 write d3plot file            09/15/23 15:42:51
           184 t 2.9654E-06 dt 3.91E-08 write d3plot file            09/15/23 15:42:52
           187 t 3.0777E-06 dt 3.68E-08 write d3plot file            09/15/23 15:42:55
           190 t 3.1960E-06 dt 4.16E-08 write d3plot file            09/15/23 15:42:57
           time = 3.2376E-06, ncycle = 190
           192 t 3.2788E-06 dt 3.88E-08 write d3plot file            09/15/23 15:42:58
           195 t 3.3979E-06 dt 3.85E-08 write d3plot file            09/15/23 15:43:00
           197 t 3.4761E-06 dt 4.04E-08 write d3plot file            09/15/23 15:43:02
           200 t 3.5958E-06 dt 4.16E-08 write d3plot file            09/15/23 15:43:04
           202 t 3.6748E-06 dt 3.24E-08 write d3plot file            09/15/23 15:43:05
           205 t 3.7821E-06 dt 4.01E-08 write d3plot file            09/15/23 15:43:08
           208 t 3.8980E-06 dt 3.79E-08 write d3plot file            09/15/23 15:43:10
           210 t 3.9736E-06 dt 3.74E-08 write d3plot file            09/15/23 15:43:11
           213 t 4.0845E-06 dt 4.02E-08 write d3plot file            09/15/23 15:43:13
           215 t 4.1662E-06 dt 4.12E-08 write d3plot file            09/15/23 15:43:15
           218 t 4.2846E-06 dt 4.04E-08 write d3plot file            09/15/23 15:43:17
           220 t 4.3617E-06 dt 3.91E-08 write d3plot file            09/15/23 15:43:18
           time = 4.4007E-06, ncycle = 220
           223 t 4.4836E-06 dt 3.87E-08 write d3plot file            09/15/23 15:43:21
           225 t 4.5636E-06 dt 4.20E-08 write d3plot file            09/15/23 15:43:22
           228 t 4.6917E-06 dt 4.26E-08 write d3plot file            09/15/23 15:43:24
           230 t 4.7746E-06 dt 4.05E-08 write d3plot file            09/15/23 15:43:26
           233 t 4.8991E-06 dt 4.24E-08 write d3plot file            09/15/23 15:43:28
           235 t 4.9825E-06 dt 3.99E-08 write d3plot file            09/15/23 15:43:29
           237 t 5.0618E-06 dt 3.95E-08 write d3plot file            09/15/23 15:43:31
           240 t 5.1818E-06 dt 4.02E-08 write d3plot file            09/15/23 15:43:33
           242 t 5.2621E-06 dt 4.03E-08 write d3plot file            09/15/23 15:43:35
           245 t 5.3836E-06 dt 4.04E-08 write d3plot file            09/15/23 15:43:37
           247 t 5.4663E-06 dt 4.22E-08 write d3plot file            09/15/23 15:43:39
           250 t 5.5928E-06 dt 4.26E-08 write d3plot file            09/15/23 15:43:41
           252 t 5.6780E-06 dt 4.16E-08 write d3plot file            09/15/23 15:43:42
           254 t 5.7615E-06 dt 4.08E-08 write d3plot file            09/15/23 15:43:44
           257 t 5.8819E-06 dt 4.13E-08 write d3plot file            09/15/23 15:43:46
           259 t 5.9664E-06 dt 4.18E-08 write d3plot file            09/15/23 15:43:48
           262 t 6.0951E-06 dt 4.30E-08 write d3plot file            09/15/23 15:43:50
           264 t 6.1808E-06 dt 4.08E-08 write d3plot file            09/15/23 15:43:52
           266 t 6.2609E-06 dt 4.32E-08 write d3plot file            09/15/23 15:43:53
           269 t 6.3886E-06 dt 4.23E-08 write d3plot file            09/15/23 15:43:56
           271 t 6.4683E-06 dt 3.99E-08 write d3plot file            09/15/23 15:43:57
           274 t 6.5920E-06 dt 4.11E-08 write d3plot file            09/15/23 15:43:59
           276 t 6.6769E-06 dt 4.32E-08 write d3plot file            09/15/23 15:44:01
           278 t 6.7617E-06 dt 4.21E-08 write d3plot file            09/15/23 15:44:02
           281 t 6.8906E-06 dt 4.39E-08 write d3plot file            09/15/23 15:44:05
           283 t 6.9769E-06 dt 4.41E-08 write d3plot file            09/15/23 15:44:06
           285 t 7.0638E-06 dt 4.34E-08 write d3plot file            09/15/23 15:44:08
           288 t 7.1906E-06 dt 4.37E-08 write d3plot file            09/15/23 15:44:10
           290 t 7.2781E-06 dt 4.24E-08 write d3plot file            09/15/23 15:44:11
           292 t 7.3642E-06 dt 4.12E-08 write d3plot file            09/15/23 15:44:13
           295 t 7.4925E-06 dt 4.40E-08 write d3plot file            09/15/23 15:44:15
           297 t 7.5784E-06 dt 4.34E-08 write d3plot file            09/15/23 15:44:17
           299 t 7.6630E-06 dt 4.21E-08 write d3plot file            09/15/23 15:44:18
           302 t 7.7922E-06 dt 4.34E-08 write d3plot file            09/15/23 15:44:20
           304 t 7.8801E-06 dt 4.19E-08 write d3plot file            09/15/23 15:44:22
           306 t 7.9652E-06 dt 4.42E-08 write d3plot file            09/15/23 15:44:23
           309 t 8.0970E-06 dt 4.45E-08 write d3plot file            09/15/23 15:44:26
           311 t 8.1842E-06 dt 4.52E-08 write d3plot file            09/15/23 15:44:27
           313 t 8.2732E-06 dt 4.44E-08 write d3plot file            09/15/23 15:44:29
           315 t 8.3618E-06 dt 4.39E-08 write d3plot file            09/15/23 15:44:30
           318 t 8.4897E-06 dt 1.07E-08 write d3plot file            09/15/23 15:44:33
           time = 8.5089E-06, ncycle = 1061
      The message file for the successful job:
       *            ANSYS 2023 R1          LEGAL NOTICES             *
       * Copyright 1971-2023 ANSYS, Inc.  All rights reserved.       *
       * Unauthorized use, distribution or duplication is            *
       * prohibited.                                                 *
       * Ansys is a registered trademark of ANSYS, Inc. or its       *
       * subsidiaries in the United States or other countries.       *
       * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
       * documentation CD or online help for the complete Legal      *
       * Notice.                                                     *
       * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION       *
       * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY      *
       * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.    *
       * The software products and documentation are furnished by    *
       * ANSYS, Inc. or its subsidiaries under a software license    *
       * agreement that contains provisions concerning               *
       * non-disclosure, copying, length and nature of use,          *
       * compliance with exporting laws, warranties, disclaimers,    *
       * limitations of liability, and remedies, and other           *
       * provisions.  The software products and documentation may be *
       * used, disclosed, transferred, or copied only in accordance  *
       * with the terms and conditions of that software license      *
       * agreement.                                                  *
       * ANSYS, Inc. is a UL registered                              *
       * ISO 9001:2015 company.                                      *
       * This product is subject to U.S. laws governing export and   *
       * re-export.                                                  *
       * For U.S. Government users, except as specifically granted   *
       * by the ANSYS, Inc. software license agreement, the use,     *
       * duplication, or disclosure by the United States Government  *
       * is subject to restrictions stated in the ANSYS, Inc.        *
       * software license agreement and FAR 12.212 (for non-DOD      *
       * licenses).                                                  *
            Date: 09/19/2023      Time: 15:42:25
           |  Date    : 11/15/2022    Time: 13:48:14           |
           |  Version : smp s R13                              |
           |  Revision: R13.1.1-13-g5480eca294                 |
           |    FFTW (multi-dimensional FFTW Library)          |
           |    Interactive Graphics                           |
           |    ANSYSLIC enabled                               |
           |    MADYMO indirect coupling (7.2 or higher)       |
           |  Licensed to:                                     |
           |  Issued by  : ANSYS                               |
           |  Platform   : WINDOWS X64 (SSE2)                  |
           |  OS Level   : Windows 8/10 & Srv 2016/2019 uam    |
           |  Compiler   : Intel Fortran XE 2019 MSVC++ 2019   |
           |  Hostname   : ENGR6321                            |
           |  Unauthorized use infringes Ansys Inc. copyrights |
           |___________________________________________________|
       Command line options: i=C:\Users\rji229\Documents\fem_sph_circular\Test\1\Run.k
                             ncpu=1
                             memory=97m
       Input file: C:\Users\rji229\Documents\fem_sph_circular\Test\1\Run.k
       Memory size from command line:    97000000
       allocating  memory to    97000000 d         544 Initial allocation
       * Neither LST nor the authors assume any responsibility for  *
       * results.                                                   *
       * LST endeavors to make the LS-DYNA code as complete,        *
       * immediately to LST through your site focus.                *
       * Copyright (C) 1990-2022                                    *
       * by Ansys, Inc.                                             *
       Beginning of keyword reader                                   09/19/23 15:42:25
       expanding   memory to       20720 d         600
       expanding   memory to       66080 d     2212719
       expanding   memory to       98580 d     2212719
       expanding   memory to     1578326 d     2272719
       expanding   memory to     1606836 d     2272719
       expanding   memory to     1629036 d     2280719
       expanding   memory to     1744036 d     2280719
        09/19/23 15:42:25
        09/19/23 15:42:25
        09/19/23 15:42:25
       expanding   memory to     1765932 d     2280719
       expanding   memory to     2012200 d     5465002
       expanding   memory to     2256992 d     5465002
       Memory required to process keyword     :    2256992
       Additional dynamic memory required     :    8647293
       contracting memory to           1 d     5465008 end of keyword reader
       Y5_PA_HV
                          ls-dyna smp s R13 R13.1.1_13_5480ec date 11/15/2022
       expanding   memory to        2001 d        1445 material, node and element data
       expanding   memory to        2071 d        1475 material properties
       expanding   memory to        2085 d     8324474 gradient of damage data
       expanding   memory to        2107 d     8324529 user control for contact interfaces
       contracting memory to        2087 d     8324531 thermal expansion 0
       expanding   memory to        2089 d     8324533 cross-sectional force definitions 0
       expanding   memory to      246880 d     8324547 temp index array for node sorting
       contracting memory to        2089 d     8569342 just because?
       expanding   memory to        4091 d    10283422 load curve data
       contracting memory to        2097 d    10283422 user_define_loading_set
       expanding   memory to        2297 d    10283422 regularize time history data
       contracting memory to        2101 d    10283422 *DEFINE_ELEMENT_DEATH
       expanding   memory to      492683 d    10528238 implicit contact 1
       contracting memory to        3101 d    10528344 contact segment data 1
       expanding   memory to     1227056 d    10528344 contact segment data 3
       contracting memory to        2101 d    14740307 contact definition
       expanding   memory to        2105 d    14740978 contact friction
       expanding   memory to     1715702 d    37752065 SPH elements
       expanding   memory to     1715802 d    38241723 rigid bodies for disp. termination
       expanding   memory to     1715872 d    38241723 save d3plot control data
       Memory required to begin solution      :    2257K
       Additional dynamically allocated memory:      41M
                                         Total:      43M
             1 t 0.0000E+00 dt 1.10E-12 flush i/o buffers            09/19/23 15:42:33
             1 t 0.0000E+00 dt 1.10E-12 write d3plot file            09/19/23 15:42:33
            96 t 9.4113E-08 dt 9.41E-09 write d3plot file            09/19/23 15:43:22
           103 t 1.8341E-07 dt 1.83E-08 write d3plot file            09/19/23 15:43:25
           108 t 2.9539E-07 dt 2.95E-08 write d3plot file            09/19/23 15:43:28
           time = 3.9317E-07, ncycle = 110
           111 t 3.9317E-07 dt 3.66E-08 write d3plot file            09/19/23 15:43:30
           113 t 4.6671E-07 dt 3.96E-08 write d3plot file            09/19/23 15:43:31
           116 t 5.9188E-07 dt 3.95E-08 write d3plot file            09/19/23 15:43:33
           time = 6.3133E-07, ncycle = 116
           118 t 6.7157E-07 dt 4.11E-08 write d3plot file            09/19/23 15:43:34
           121 t 7.9410E-07 dt 4.17E-08 write d3plot file            09/19/23 15:43:37
           123 t 8.8038E-07 dt 4.54E-08 write d3plot file            09/19/23 15:43:38
           time = 9.2573E-07, ncycle = 123
           125 t 9.6982E-07 dt 4.65E-08 write d3plot file            09/19/23 15:43:40
           127 t 1.0610E-06 dt 4.36E-08 write d3plot file            09/19/23 15:43:42
           130 t 1.1918E-06 dt 4.53E-08 write d3plot file            09/19/23 15:43:44
           132 t 1.2849E-06 dt 4.77E-08 write d3plot file            09/19/23 15:43:46
           134 t 1.3799E-06 dt 4.74E-08 write d3plot file            09/19/23 15:43:48
           136 t 1.4746E-06 dt 4.63E-08 write d3plot file            09/19/23 15:43:50
           138 t 1.5663E-06 dt 4.43E-08 write d3plot file            09/19/23 15:43:51
           time = 1.6532E-06, ncycle = 139
           140 t 1.6532E-06 dt 4.69E-08 write d3plot file            09/19/23 15:43:53
           143 t 1.7969E-06 dt 4.83E-08 write d3plot file            09/19/23 15:43:56
           145 t 1.8806E-06 dt 3.90E-08 write d3plot file            09/19/23 15:43:57
           147 t 1.9626E-06 dt 4.46E-08 write d3plot file            09/19/23 15:43:59
           150 t 2.0788E-06 dt 3.60E-08 write d3plot file            09/19/23 15:44:02
           153 t 2.1979E-06 dt 4.44E-08 write d3plot file            09/19/23 15:44:05
           155 t 2.2817E-06 dt 3.75E-08 write d3plot file            09/19/23 15:44:06
           158 t 2.3922E-06 dt 3.80E-08 write d3plot file            09/19/23 15:44:09
           160 t 2.4720E-06 dt 4.60E-08 write d3plot file            09/19/23 15:44:11
           time = 2.5625E-06, ncycle = 161
           162 t 2.5625E-06 dt 3.95E-08 write d3plot file            09/19/23 15:44:13
           time = 2.6020E-06, ncycle = 162
           time = 2.6867E-06, ncycle = 164
           165 t 2.6867E-06 dt 4.71E-08 write d3plot file            09/19/23 15:44:15
           167 t 2.7825E-06 dt 4.80E-08 write d3plot file            09/19/23 15:44:17
           time = 2.8306E-06, ncycle = 167
           169 t 2.8726E-06 dt 3.94E-08 write d3plot file            09/19/23 15:44:19
           171 t 2.9541E-06 dt 4.63E-08 write d3plot file            09/19/23 15:44:21
           174 t 3.0939E-06 dt 4.62E-08 write d3plot file            09/19/23 15:44:24
           176 t 3.1808E-06 dt 4.38E-08 write d3plot file            09/19/23 15:44:26
           178 t 3.2728E-06 dt 4.89E-08 write d3plot file            09/19/23 15:44:28
           180 t 3.3658E-06 dt 4.24E-08 write d3plot file            09/19/23 15:44:30
           183 t 3.4967E-06 dt 4.81E-08 write d3plot file            09/19/23 15:44:33
           time = 3.5926E-06, ncycle = 184
           185 t 3.5926E-06 dt 4.22E-08 write d3plot file            09/19/23 15:44:35
           187 t 3.6749E-06 dt 4.20E-08 write d3plot file            09/19/23 15:44:37
           189 t 3.7631E-06 dt 4.85E-08 write d3plot file            09/19/23 15:44:39
           time = 3.8117E-06, ncycle = 189
           191 t 3.8592E-06 dt 4.25E-08 write d3plot file            09/19/23 15:44:41
           194 t 3.9923E-06 dt 4.82E-08 write d3plot file            09/19/23 15:44:43
           196 t 4.0878E-06 dt 4.72E-08 write d3plot file            09/19/23 15:44:45
           198 t 4.1826E-06 dt 4.38E-08 write d3plot file            09/19/23 15:44:47
           200 t 4.2747E-06 dt 4.86E-08 write d3plot file            09/19/23 15:44:49
           202 t 4.3722E-06 dt 4.90E-08 write d3plot file            09/19/23 15:44:51
           204 t 4.4688E-06 dt 4.47E-08 write d3plot file            09/19/23 15:44:53
           206 t 4.5568E-06 dt 4.54E-08 write d3plot file            09/19/23 15:44:55
           209 t 4.6991E-06 dt 4.69E-08 write d3plot file            09/19/23 15:44:58
           211 t 4.7946E-06 dt 4.44E-08 write d3plot file            09/19/23 15:45:00
           213 t 4.8792E-06 dt 4.17E-08 write d3plot file            09/19/23 15:45:01
           215 t 4.9669E-06 dt 4.79E-08 write d3plot file            09/19/23 15:45:04
           217 t 5.0629E-06 dt 4.76E-08 write d3plot file            09/19/23 15:45:06
           220 t 5.1926E-06 dt 4.49E-08 write d3plot file            09/19/23 15:45:09
           222 t 5.2864E-06 dt 4.41E-08 write d3plot file            09/19/23 15:45:11
           224 t 5.3770E-06 dt 4.62E-08 write d3plot file            09/19/23 15:45:13
           226 t 5.4674E-06 dt 4.83E-08 write d3plot file            09/19/23 15:45:15
           228 t 5.5637E-06 dt 4.82E-08 write d3plot file            09/19/23 15:45:17
           230 t 5.6554E-06 dt 4.69E-08 write d3plot file            09/19/23 15:45:19
           233 t 5.7966E-06 dt 4.41E-08 write d3plot file            09/19/23 15:45:22
           235 t 5.8892E-06 dt 4.64E-08 write d3plot file            09/19/23 15:45:24
           237 t 5.9818E-06 dt 4.82E-08 write d3plot file            09/19/23 15:45:25
           239 t 6.0788E-06 dt 4.88E-08 write d3plot file            09/19/23 15:45:27
           241 t 6.1725E-06 dt 4.63E-08 write d3plot file            09/19/23 15:45:28
           243 t 6.2657E-06 dt 4.86E-08 write d3plot file            09/19/23 15:45:30
           245 t 6.3630E-06 dt 4.79E-08 write d3plot file            09/19/23 15:45:31
           247 t 6.4585E-06 dt 4.50E-08 write d3plot file            09/19/23 15:45:33
           250 t 6.5981E-06 dt 4.74E-08 write d3plot file            09/19/23 15:45:35
           252 t 6.6944E-06 dt 4.91E-08 write d3plot file            09/19/23 15:45:36
           254 t 6.7913E-06 dt 4.90E-08 write d3plot file            09/19/23 15:45:38
           256 t 6.8895E-06 dt 4.78E-08 write d3plot file            09/19/23 15:45:40
           258 t 6.9860E-06 dt 4.74E-08 write d3plot file            09/19/23 15:45:41
           260 t 7.0814E-06 dt 4.89E-08 write d3plot file            09/19/23 15:45:43
           262 t 7.1792E-06 dt 4.88E-08 write d3plot file            09/19/23 15:45:44
           264 t 7.2768E-06 dt 4.78E-08 write d3plot file            09/19/23 15:45:46
           266 t 7.3730E-06 dt 4.87E-08 write d3plot file            09/19/23 15:45:47
           268 t 7.4703E-06 dt 4.86E-08 write d3plot file            09/19/23 15:45:49
           270 t 7.5675E-06 dt 4.86E-08 write d3plot file            09/19/23 15:45:50
           272 t 7.6649E-06 dt 4.66E-08 write d3plot file            09/19/23 15:45:52
           274 t 7.7580E-06 dt 4.66E-08 write d3plot file            09/19/23 15:45:53
           277 t 7.8993E-06 dt 4.65E-08 write d3plot file            09/19/23 15:45:56
           279 t 7.9947E-06 dt 4.85E-08 write d3plot file            09/19/23 15:45:57
           281 t 8.0890E-06 dt 4.70E-08 write d3plot file            09/19/23 15:45:59
           time = 8.1844E-06, ncycle = 282
           283 t 8.1844E-06 dt 4.86E-08 write d3plot file            09/19/23 15:46:01
           time = 8.2330E-06, ncycle = 283
           285 t 8.2819E-06 dt 4.88E-08 write d3plot file            09/19/23 15:46:02
           287 t 8.3787E-06 dt 4.88E-08 write d3plot file            09/19/23 15:46:04
           289 t 8.4710E-06 dt 4.78E-08 write d3plot file            09/19/23 15:46:05
           291 t 8.5661E-06 dt 4.87E-08 write d3plot file            09/19/23 15:46:07
           293 t 8.6636E-06 dt 4.89E-08 write d3plot file            09/19/23 15:46:08
           295 t 8.7594E-06 dt 4.79E-08 write d3plot file            09/19/23 15:46:10
           297 t 8.8559E-06 dt 4.85E-08 write d3plot file            09/19/23 15:46:11
           299 t 8.9530E-06 dt 4.84E-08 write d3plot file            09/19/23 15:46:13
           302 t 9.0990E-06 dt 4.87E-08 write d3plot file            09/19/23 15:46:15
           304 t 9.1965E-06 dt 4.56E-08 write d3plot file            09/19/23 15:46:17
           306 t 9.2881E-06 dt 4.69E-08 write d3plot file            09/19/23 15:46:18
           308 t 9.3827E-06 dt 4.90E-08 write d3plot file            09/19/23 15:46:20
           310 t 9.4806E-06 dt 4.82E-08 write d3plot file            09/19/23 15:46:21
           312 t 9.5729E-06 dt 4.67E-08 write d3plot file            09/19/23 15:46:23
           314 t 9.6638E-06 dt 4.66E-08 write d3plot file            09/19/23 15:46:24
           316 t 9.7579E-06 dt 4.85E-08 write d3plot file            09/19/23 15:46:26
           time = 9.8512E-06, ncycle = 317
           319 t 9.8980E-06 dt 4.36E-08 write d3plot file            09/19/23 15:46:28
           321 t 9.9851E-06 dt 4.78E-08 write d3plot file            09/19/23 15:46:30
       *** termination time reached ***
           321 t 1.0033E-05 dt 4.78E-08 write d3dump01 file          09/19/23 15:46:30
           321 t 1.0033E-05 dt 4.78E-08 write d3plot file            09/19/23 15:46:30
       N o r m a l    t e r m i n a t i o n                          09/19/23 15:46:30
       Memory required to complete solution   :    2257K
       Additional dynamically allocated memory:     150M
                                         Total:     152M
       T i m i n g   i n f o r m a t i o n
                              CPU(seconds)   %CPU  Clock(seconds) %Clock
        Keyword Processing ... 1.0000E+00    0.41     4.9200E-01    0.20
          KW Reading ......... 1.0000E+00    0.41     3.3300E-01    0.14
          KW Writing ......... 0.0000E+00    0.00     3.1000E-02    0.01
        Initialization ....... 8.0000E+00    3.25     8.7360E+00    3.54
          Init Proc Phase 1 .. 7.0000E+00    2.85     7.0600E+00    2.86
          Init Proc Phase 2 .. 0.0000E+00    0.00     1.9000E-02    0.01
        Element processing ... 2.3200E+02   94.31     2.2922E+02   93.01
          SPH ................ 2.3200E+02   94.31     2.2922E+02   93.01
        Binary databases ..... 5.0000E+00    2.03     7.2970E+00    2.96
        ASCII database ....... 0.0000E+00    0.00     2.8000E-02    0.01
        Time step size ....... 0.0000E+00    0.00     1.5000E-02    0.01
        Others ............... 0.0000E+00    0.00     5.0000E-03    0.00
        Misc. 1 .............. 0.0000E+00    0.00     6.8000E-02    0.03
          Force to Accel ..... 0.0000E+00    0.00     6.6000E-02    0.03
        Misc. 2 .............. 0.0000E+00    0.00     3.7300E-01    0.15
        Misc. 3 .............. 0.0000E+00    0.00     1.7500E-01    0.07
        Misc. 4 .............. 0.0000E+00    0.00     4.3000E-02    0.02
          Timestep Init ...... 0.0000E+00    0.00     4.3000E-02    0.02
        T o t a l s            2.4600E+02  100.00     2.4645E+02  100.00
       Problem time       =    1.0033E-05
       Problem cycle      =       321
       Total CPU time     =       246 seconds (   0 hours  4 minutes  6 seconds)
       CPU time per zone cycle  =       3016.115 nanoseconds
       Clock time per zone cycle=       3018.953 nanoseconds
       Number of CPU's    1
       NLQ used/max     136/  136
       Start time   09/19/2023 15:42:25
       End time     09/19/2023 15:46:30
       Elapsed time     245 seconds for     321 cycles using  1 SMP thread
                   (      0 hour   4 minutes  5 seconds)
    • Loic Ivaldi
      Hello, what kind of simulation you want to achieve ?
      Check how the simulation behave. If you have this :
      maybe you can see something wrong in the plot.
      - Use the latest version.
      - Check carefully material properties
      - try lowering the timestep
      - try with VP=0
      Best Regards,
      Loïc
