September 15, 2022 at 1:54 am
September 15, 2022 at 4:31 pm
Guilin Sun
Ansys EmployeePlease use the following script:
addfdtd;
set("set simulation bandwidth",1);
set("simulation wavelength min",1e-6);
set("simulation wavelength max",5e-6);
- Error on Lumerical device
2642
2110
1335
1112
461
