July 12, 2019 at 6:11 am
jk820912168
SubscriberHello,
I run thermal electric analysis of ansys,and usually error message are showed,
An internal solution magnitude limit was exceeded.Please check your Environment for inappropriate load values or insufficient supports. You may select the offending object and/or geometry via RMB on this warning in the Messages window. Please see the Troubleshooting section of the Help System for more information.
I try to search error message,but that fix method don't help me.
How can I do? Thanks!
July 12, 2019 at 9:21 am
Ansys EmployeeThanks for putting in large images: makes it much easier to read!
I suspect you've either added too high a force/expansion coefficient to a component or it's not fastened to anything: check what's holding the model together.
July 22, 2019 at 1:38 am
jk820912168
SubscriberHi,rwoolhou
Thanks for your reply!
About material coefficient, I reference two websites.
1. http://www.matweb.com/index.aspx
2. https://www.azom.com/properties.aspx?ArticleID=599
The model analysis setting is default,ex: contacts are bonded, mesh setting are standard mechanical.
- Maxwell, HFSS or Q3D?
- Error
3658
2534
1745
1226
580
