Preprocessing
Preprocessing
About to create the bicycle mesh
    • Chien Hsun
      Hi everyone,
      I have a problem about the use ICEM to create the bicycle mesh to simulate in CFD, but when I finish the geometry in S.W and translate to igs , x_t , x_b , step.. anyone that I can try, and import to ICEM, I can see a good geometry surface in ICEM, but when I use the all tri mesh to create the shell mesh on frame, the fork will fail ,I don't know how to fix it, anybody could help me, I will thank you very much!!
    • raul.raghav
      Did you build topology after importing the geometry? Could you share your geometry file here?
    • Chien Hsun
      Yes, I have topology and fixed the broken surface, No problem, I upload on google, thanks
      https://drive.google.com/drive/folders/1VemDnjxjQKsOWQ8kejSAFwkov65wY95D?usp=sharing
    • raul.raghav
      Chien, a quick question, are you trying to analyze the external flow around the bicycle or an FSI study?
    • Vishal Ganore
      Looks very interesting project.
      Have you finished CFD study? I assume you are targeting for 1 way FSI, in that case, CFD analysis don't need such a detailed mesh for bicycle body.
Viewing 4 reply threads
