Absorbed Visible Solar Flux — Unexpected Results?
    • patrickm7995
      I have a thin plate with the bottom surface receiving solar flux, and the other surfaces being fully transparent and the inside of the geometry being air with very low (1e-5) density.
      This bottom wall was set to 0 transmissivity and 0 absorptivity for this case, so it was expected that the solar radiation coming in (1377 W/m2) would be split between reflectivity in the IR and visible, 688.5 W/m2, which occured.
      However, the absorbed visible solar flux map was also showing a value, which was unexpected. The absorbed IR was as expected, 0 W/m2.
      Does anyone have any reasons this may be occuring? Thank you.
    • Swathi V. V.
      Can you please check your settings again?
      Please note absorbed visible solar flux is not evalueted for opaque surface.
      • patrickm7995
        Thank you for your reply. Sorry, I am confused: opaque surfaces do not have absorbed solar flux?
