June 23, 2023 at 12:27 pm
sagar
SubscriberHow to get absorption in RCWA solver? I want to do parameter optimization by varying different parameters for absorption. Can you please suggest how to do it?
June 23, 2023 at 8:12 pm
June 23, 2023 at 8:38 pm
sagar
SubscriberBut Rp and Rs are the reflections corresponding to p-polarized and s-polarized light. But I want to calculate absorption. One way to calculate is (1-Rp-Tp). But is it possible to calculate through the volume integration over the region (the way we do in FDTD)?
June 26, 2023 at 4:37 pm
Guilin Sun
Ansys EmployeeYou are right that currently you can use (1-Rp-Tp).
Please note that the volume integration method is less accurate since it involves more data calculation. If you are not calcualting the spatial-absorption distribution, using (1-Rp-Tp) should be sufificient.
Improvement for RCWA outputs is under the way.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7780
4508
2973
1449
1322
