November 26, 2019 at 7:00 pm
ifdandrea
SubscriberHi, The student version "Academic Teaching Introductory" doesn't work. When I click on Solve button the calculation will block. I'm trying to follow the Cornell University webinar but with the 2019 R2 release I can't work. Is there someone who knows if the student version is so limited?
Thank You
November 27, 2019 at 12:18 am
tsiriaks
Ansys EmployeePlease provide the exact error message that you saw or take screenshot of it and post it inline here.
November 27, 2019 at 3:08 pm
ifdandrea
1) when I try to change the material property I go to geometry and to SYS/surf, then I click on it and below appairs the material raw where an arrow-button should open a pop-up window and it should show me all the functions/options I can use. Instead, popup window is totally empty. So I have found another way as show in the images above. 2) The solution never complete the calculation, why?THNAK YOU
November 28, 2019 at 12:10 am
tsiriaks
Ansys EmployeeFor #1 , I recommend to post the question in Physics Simulation -> Structural Mechanics section
For #2 , if you just create a text box , then use static structural with default material assignment, add simple BC's and solve, do you get the same issue ?
November 28, 2019 at 8:32 am
ifdandrea
SubscriberHello,
for #2, What do you mean with "if you just create a text box"? In general I'm trying to resolve a thermal steady-state problem with T = cost on one side, dT/dn=0 for two walls and a convection heat exchange on the last one.
for #1, May you give me the link of Physics Simulation -> Structural Mechanics section?
THANK YOU
December 3, 2019 at 12:04 am
tsiriaks
Ansys EmployeeThe purpose of #2 is to test whether a simple analysis/model has this same issue.
For #1, when you create a new thread (the New Discussion button), in the Choose Category box , you can select Physics Simulation -> Structural Mechanics section
- License Error
- Workbench not opening
- Workbench error
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
5268
3299
2469
