March 10, 2023 at 1:03 pm
Abhijna Raghava Simhan
SubscriberI have been trying to install Ansys 2022 R2 fluids package and am getting a license error and fluent is not working. However workbench is running. Can anyone please suggest a fast solution to this ?
March 10, 2023 at 3:44 pm
Ansys EmployeeWorkbench doesn't need a licence so tends to work regardless. Have you installed as Admin? Is this the Student bundle or a licenced build? If the latter, did you install and configure the licence manager?
March 10, 2023 at 4:19 pm
March 10, 2023 at 4:36 pm
Ansys EmployeeIs there anything else in the text window, or has the solver frozen when trying to launch?
March 10, 2023 at 4:42 pm
SubscriberAbove this, it says connected to the license server and then it is frozen. The reading of cores and the the text related to the cleanup script does not appear
March 13, 2023 at 11:43 am
George Karnos
Ansys EmployeeThere should be a debug log file under: %TEMP\.ansys for fluent
Does this file have any errors contained within it?Also, what is the output from:
Open a Dos command prompt window
Type in:set
March 13, 2023 at 3:45 pm
March 13, 2023 at 4:03 pm
George Karnos
Ansys EmployeeWhat is contained in the directory:
%TEMP%\.ansys
- License Error
- Workbench error
- Workbench not opening
- Ansys2021R2 ansys212 seg faults immediately on RHEL8.2
3930
2649
1861
1272
610
