Acceleration as output
    • mzhossain2001
      Is it possible to get acceleration as a direct output in Ansys? If so how? A detail discussion will be appreciated. Thanksn
    • peteroznewman
      If you are in Workbench and have Mechanical Open on a Transient Structural model, click on the Solution Branch then click on the Worksheet button on the ribbon. You will see all the available results. Note the name of the Expression for the acceleration component you want to plot. I have highlighted AX.nInsert a User Defined Result. On the yellow line with the = on it, type AX, then Evaluate. You will be contouring nodal x-component of acceleration values.n
    • mzhossain2001
      Can it be possible in Ansys Mechanical APDL.n
