Ansys Free Student Software
Access denied
    • Parthasarathi
      I made a query in Population balance modeling? When I clicked "Create Discussion", I received the message as : You don't have permission to access "http://studentcommunity.ansys.com/topic/create/" on this server.
      Reference #18.8d346d68.1545192491.3b47ebbf.
      But I made a dummy discussion with no words, it was posted. Where is the error?
    • Sandeep Medikonda
      Are you copy-pasting Text from elsewhere? Sometimes the embedded HTML or inbuilt formatted text can cause this. Try to type everything in or when you copy-paste use Ctrl+Shift+V?
      Sandeep
    • Parthasarathi
      Thank you Sandeep. First I typed in the online portal, and clicked "Create discussion". The screen didn't change for a long time. Then I removed the bulletin points and clicked. Again I'm getting Access denied. Does any limitations with the words or the file size.
      There's a file size limit but it's fairly large (we can post projects). I've had a few problems and found if you create a blank post and edit it'll sometimes bypass whatever was causing the problem.
      As you've created a thread here it must be working!  As an aside staff can't open/download attachments so maybe create a few posts with all of the images etc inline?
Viewing 3 reply threads
