Access results at integration points
    • wandersonsantos
      Hello people!
      I used the command ERESX, NO. With that, I keep the results in the integration points.
      Which command to access the results at the integration points?
      I want to take these values and make some additional accounts.
      In the image below follows the valleys I want to get. These results can be viewed in General Posproc> List results> Element solution ...
Viewing 0 reply threads
