October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeIs it possible to access the results of different design points within Mechanical?
October 17, 2017 at 9:59 am
Arun
Ansys EmployeeYes. Follow the procedure below; 1. Close Mechanical Window. 2. Open the Parameter Set Window 3. Right Click on desired Design Point Name in the Table of Design Option window and say Set as Current. 4. Up on opening the Mechanical Window loads the results of selected design point. For this to work; Results of Design Point must be saved before solving.
April 23, 2020 at 7:52 am
F123rooq
SubscriberWhat if you do not have the 'set as current' button available, because you did not check the 'retain' box before solution, how can you then see the results of each of the design points, just the numbers, not the pictures, because the pictures will only be available for each if you check the 'retain' box.
Thank you.
Kind Regards,
2066
1285
1096
459
