Accessing Cell Variables on moving “velocity-inlet” in a Dynamic Mesh
    • gsabhishek
      I am solving a problem where a molten liquid is filling a cylindrical cavity. The molten liquid has a temperature profile along the radial direction.
      I use dynamic meshed axisymmetric cylinder with the following boundaries,
      1) "bottom" - wall
      2) "radial_surface"- wall + deformable in dynamic mesh
      3) "axis" - axis + deformable in dynamic mesh
      4) "top" - velocity-inlet + UDF in dynamic mesh
      DEFINE_GRID_MOTION(topMotion,domain,dt,time,dtime)
         #if !RP_HOST
         Thread *tf = DT_THREAD(dt);
         face_t f;
         Node *v;
         real NV_VEC(vel);
         NV_D(vel,=,0.000313,0,0);
         int n;
         if(time<1614.0)
            SET_DEFORMING_THREAD_FLAG(THREAD_T0(tf));
            begin_f_loop(f,tf)
               f_node_loop(f,tf,n)
                  v = F_NODE(f,tf,n);
                  if(NODE_POS_NEED_UPDATE(v))
                     NODE_POS_UPDATED(v);
                     NV_S(vel,*=,dtime);
                     NV_V(NODE_COORD(v),+=,vel);
            end_f_loop(f,tf);
         #endif /*!RP_HOST*/
      Here I would like to set a inlet profile for temperature. For that I can add the following
      1) To get the cell thread adjacent to the face,
      Thread *tc = THREAD_T0(tf);
      2)Inside "begin_f_loop(f,tf)", we can get the cell index by
      cell_t c = F_C0(f,tf);
      3) This is where I am stuck as I can neither set C_T(c,tc) or F_T(f,tf). Accessing either gives segmentation fault. How do I proceed here?
      thanks
      Abhishek
    • Karthik R
      Administrator
      Hello I'm not sure I completely understand your question - but can you not use Fluent expressions for defining an Inlet Velocity profile?
      Karthik
