Tagged: design-points, export-data, parameter-set, python-scripting
March 3, 2023 at 1:43 amSubscriber
I have been using the python code feature to automatically export results from different design points runs.
I would like to save the files using some of the varying parameters described in the design points (the value for "P1" for example).
How can I do this?
I was able to access the design point number using the following code line:
import os
import wbjn
dpn=wbjn.ExecuteCommand(ExtAPI,"returnValue(a+Parameters.GetActiveDesignPoint().Name)",a="DP")credit: https://www.linkedin.com/pulse/script-tip-friday-python-code-object-mechanical-
March 3, 2023 at 11:51 am
Aniket
Ansys EmployeePlease check the source code of Multi object export app on Ansys store:
Ansys Store Multi Object ExportV1.1 created by Ansys Inc
-Aniket
March 3, 2023 at 5:50 pmSubscriber
Thank you.
It's another way to perform the export, but I don't see anything specifically about accessing the design point parameters.
Is there a way to access the design point parameters from ANSYS Mechanical?
3694
2564
1765
1236
592
