February 15, 2022 at 9:08 pm
shashank1
Subscriberwhen I validate my design i get an error saying the A and B are intersecting. So when I unite /subtract/intersect A and B it becomes invalid object and returns the following error
Acis error: "Fail to make union..Acis Error 21091 - Two or more vertices of one body mapped to a single entity of other body"
Did any one face similar issue?
February 16, 2022 at 5:31 amKeyur Kanade
Ansys EmployeeAre you using SpaceClaim?
Please check geometry in SpaceClaim.
Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
The geometry should be error free to proceed.
If geometry has any errors, please modify/recreate geometry at those places.
Please go through help manual for more details
Regards Keyur
February 16, 2022 at 5:58 pmshashank1
SubscriberNope, My geometry is in HFSS. I am using human head model in HFSS. I cannot recreate the model in Spaceclaim as the model is complex human body and HFSS wont export the cad file.
February 23, 2022 at 2:33 pmPraneeth
Please share more information about your query to help us serve you better.
It looks like two objects of different materials are intersecting with each other. So subtracting or uniting will not solve your issue if you do not intend.
Does human head model intersect with other objects in your simulation model?
If not, there might be some problem with the human head model as it is a complex model. Kindly go through "Model Preparation Commands" section of the HFSS help document to reduce the errors in the human head model.
All the very best Praneeth.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
