September 17, 2018 at 3:28 pm
XWang
I use Modal/Modal Acoustics (V18.2) with acoustic imported temperature option to evaluate acoustic pressure (eigenfrequencies). The external temperature ASCII data file originates from Fluent solutions. The model window is crashed shortly after I hit 'Generate' button to load the data file. I tried to search available resources to check the format requirement for imported temperature, and how to convert fluent exported ASCII data to Mechanical Modal data, but I couldn't find a solution. Does anyone know how to generate compatible acoustic imported temperature data that can be used for acoustic analysis? Thank you
September 20, 2018 at 1:10 am
Karthik R
AdministratorHello,
I am moving your question to the Fluid dynamics thread for better visibility.
thank you.
Best,
Karthik
2706
2146
1357
1144
462
