January 13, 2022 at 8:18 pm
sf22
SubscriberWhen i Export a table to edit entries, i get all columns clumped together in a single cell.
i can split the row to different columns manually, but whenever i try to import, i get this error:
January 13, 2022 at 9:20 pmsf22
SubscriberEDIT: Please delete, solved using windows setting
May 26, 2022 at 7:20 amTrailer
SubscriberHello sf22 I have the same problem.
Did you managed to solve it?
Trending discussions- how to improve the inflation quality at sharp corners?
- check element type
- Meshing Error
- How to resolve Mesh Failure
- Error in meshing
3862
2639
1859
1254
600
