December 13, 2021 at 8:04 am
schenlor
SubscriberI want to launch the ACP setup but it will not start. I have tried opening other files to see if the problem is in my file. However, it did not work with any file, so the problem must be somewhere else.
Mechanical and DesignModeler open without problems, only the ACP setup causes problems.
I use a student license and am connected to the server via VPN.
What are the next steps I can try?
December 13, 2021 at 8:32 amRuturaj Gavali
Ansys EmployeeHey !
Please refer to the following discussions:
Unable to load "Setup" in ACP Pre ÔÇö Ansys Learning Forum
I was trying to work in ACP (PRE). When I updated the module, I got this error. Please Help. ÔÇö Ansys Learning Forum
Thanks!
For more information, check out the following links:
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
December 15, 2021 at 5:30 pmschenlor
SubscriberIn the meantime I have found out more. I was able to reproduce and correct the problem.
The error occurs when multiple screens are used.
E.g. opening ACP module - moving the window to the second screen. - If now the second screen is unhooked the ACP module can not be loaded anymore. - If the second screen is attached again, the ACP window can be moved back to the primary screen and the ACP module opens normally.
Thanks anyway
December 15, 2021 at 5:40 pmRob
Ansys Employeeif you min/max the screen from the task bar it should reappear on the main screen. It's a bonus "feature" of Windows software.
December 15, 2021 at 7:53 pmschenlor
Yes I know this "feature" :) I feel like a noob right now haha
Thank you
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to access the ANSYS Online Help
- search does not work.
- Discussion Creation Error
- Regarding not getting link of click “accepted answer”
- unable to open the saved ansys file.
- Images added to Posts are scaled UP and down
- Access to ANSYS Customer Portal?
- Access Denied Error When I Send Post
- ACP module does not start
- I can’t create a discussion again
2656
2120
1347
1118
461
