ACP parameter set problem
    • wenxin9564
      Hi, everyone!
      I’m using ACP to analyze some structures, but I got a problem with the parameter set.
      When I add the parameters in ACP(Post). For example, I tried four different failure criteria results.
      The code for four parameters I put are:
      return_value = db.models.solutions.plots.minmax[1]
      As you can see the value have shown the value I want from the solution, but when I went to the parameter set, the first DoE will record these four values, However, the following DoE only have one Parameter.1 updated! The rest three parameters didn’t update as I want and only copy the first DoE results.
      What should I do to have all the values updated? Or something wrong with the code I put or the link between blocks?
      Please give me some suggestions! Thank you in advance!
      Regards
      Wenxin
    • wenxin9564
