October 9, 2018 at 12:01 pm
Marvin
Subscriber -
October 15, 2018 at 2:37 pm
Sandeep Medikonda
Ansys EmployeeMarvin,
Can you open your model and show the details? Is the error in Static Structural part or the ACP part? check the time at which you are requesting the result, is it last?
Sandeep -
October 27, 2018 at 11:22 pm
Marvin
SubscriberHi Sandeep,
sorry for the late answer, I had hardware related problems.
I am not sure where do I request the time of the result. I tried to change ''Store Results At'' and ''Retain Files after full Solve'' from ''No'' and ''All time Points'' to ''Yes'' and ''Last time Point''. In both cases the error is the same.
The error shows up in ACP (Post).
I also have some Command Snippets, that I need, maybe they are interfering in some way?
Marvin
October 29, 2018 at 3:40 pm
Sean Harvey
Ansys EmployeeHi Marvin,
From what I see in the commands, they are not affecting the result file, but can you try and suppress and run w/o them? I realize the one that has the D commands is needed to hold the model and will affect the run, but can you put in alternate constraints via built in methods (fixed support for example). Just as a test. Try that and let us know. Thank you.
Sean -
October 29, 2018 at 7:06 pm
October 29, 2018 at 7:39 pm
Sean Harvey
OK, let me inquire with our development staff. This is not something we have seen recorded as an issue. Thanks for your patience.
Sean -
October 29, 2018 at 8:47 pm
Sean Harvey
At 17.0 we saw some minor issues, so please try these steps.
- Perform a clear generated data on ACP Pre Setup cell
- Update the solution on the WB project schematic
- Refresh ACP Post
- Launch it and update the model in ACP Post
You could also try deleting and connecting back a new ACP Post.
Now, if these do not work could you update to a more current version?
Thank you
Sean
2086
1317
1108
459
