December 4, 2020 at 7:13 am
cagdasakalin
SubscriberDear all,
According to the "Basic Scripting" procedure it is obvious that in ACP Pre module we can read copy commands appearing in "History View" and paste them in a notepad and save it as *.py.
December 8, 2020 at 8:56 pmjulius.langenhorst
SubscriberWhy are you trying to create a new model if it already exists? Have you tried renaming it?nDecember 14, 2020 at 8:52 pmGary Stofan
Ansys EmployeeStart with an new ACP, then run your script. nViewing 2 reply threads- The topic ‘ACP Pre Script file reading’ is closed to new replies.
Trending discussions- Floating point exception
- How to indetify baffles in Fluent meshing
- How to delete elements on Ansys Workbench
- Meshing cylindrical bodies with holes
- Quality failure limits are exceeded on some solid bodies… in ansys meshing
- Problems in the meshing of my geometry
- Ansys Mechanical – Python Scripting – Access and input parameter
- Mesh Element Quality Display Style Not Showing
- Local mesh refinement with targeted edge lengths at specified areas
- Fluent Meshing Batch Mode – Problems workflow commands
8808
4658
3155
1688
1478
