ACP transfers wrong ply assignment to solver
    • mene
      Good day to all
      I am trying to simulate a composite structure comprised by a plate with top hat stiffeners and some solids using ACP. However when I transfer through workbench the data to the static structural in order to solve, the plies I created and assigned on the oriented selection sets in ACP are assigned to random elements and not where I assigned them.
      Does anybody have any idea why this might be happening?
      I have also attached the zipped .wbjd file in case someone wants to take a look
      Thank you
      Menelaos
    • Wenlong
      Hi Menelaos,
      The file you attached is not an archived workbench file so it cannot be viewed. Please choose "archive" in the File menu of Workbench.
      Bests,
      Wenlong
    • mene
      Dear Wenlong
      Thank you for your reply
      The problematic module is "D". Please see attached
    • Wenlong
      Hi Menelaos,
      The issue happens when you include solids in your composite creation in ACP(Pre). You want to make sure there are shells only in the model of ACP(Pre).
      To include solid in the final model, you can create another mechanical module, import the same geometry, and suppress all the shells.
      Hope this helps.
      Bests,
      Wenlong
    • mene
      I will look into it.
      Thank you
      Menelaos
Viewing 4 reply threads
