September 1, 2019 at 1:32 pm
September 4, 2019 at 2:44 am
Sandeep Medikonda
Ansys EmployeeWhat do you have under connections? Use Body Interactions if you aren't doing this already. Also, set the scale to true Scale.
If these don't help, please post snapshots of you contact settings.
September 5, 2019 at 9:34 am
shashankp
Subscriberthank you sandeep.
there are body interactions by default. i am getting this problem when there are "upside down elements" in the solid model.
although i export shell composite data into explicit dynamics, i was checking for upside down elements in solid model and when there are no such upside down elements, the material deforms properly.
can you please tell me how i can prevent upsidedown elements
July 16, 2020 at 6:08 pm
naeem
SubscriberThank you brother @shashankp for asking this question.
I'm getting the same problem would be be so kind to share solution it with me.
Thanks
2066
1279
1096
457
