Discovery Import
Discovery Import
ACT Addin is not loaded
    • trong.luong
      Hi SpaceClaim Support,
      I am using SpaceClaim 2020 R2 and its ACT Addin cannot be loaded (see that attached image). I would like to use it to install some custom ACTs.
      Could you please help?
      Thanks!
    • Naresh Patre
      hello Huu Trong Luong
      Did you encounter any error while installing SpaceClaim? Can you try uninstalling and reinstalling the software and see if that helps to resolve the issue? While installing, please ensure that you have first unzipped the installation files and you run the setup.exe in administrative mode.
    • trong.luong
      Hi Naresh,
      I installed the software with Administrative right. I will try again and let you know then.
      Best regards,
      Trong
    • trong.luong
      Hi Naresh,
      I uninstalled and clean installed the software again with Administrative right. However, it does not fix the issue.
      Best regards,
      Trong
    • Naresh Patre
      Hello Matt Madore
      Do you have any suggestions to resolve this ACT addin issue?
    • ANSYS_MMadore
      Huu Trong Luong can you share the text of your C:Program FilesAnsys Incinstall.log and install.err files?
      • trong.luong
        Matt Madore Sorry for the delay!
        I removed the software and reinstalled it with Admin right. Here are the log files.
        🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • ANSYS_MMadore
      Are you still seeing the ACT issue with the new install?  Have you tried deleting the %APPDATA%Ansysv202 and v211 directories?
      • trong.luong
        Matt Madore I still have the ACT issue. I did not delete  %APPDATA%Ansysv202 and v211 directories. Should I delete them before or after installation?
    • trong.luong
      Hi Matt,
      I would like to resume this topic. Is there any update or guidance to fix this yet?
      Best regards,
      Trong
Viewing 7 reply threads
