Ansys Products
Ansys Products
ACT Mechanical Coordinates Units
    • Azmin Zamsanirani
      Im doing a ACT entension to find the node with the average temperature. I manage to do it but the coordinates is diplaying in unit U.S Customary (In) only. How can I make it flexible which mean it will change when the user change the unit from the Home tab.
    • mjmiddle
      unit="Coordinate" is not a valid unit string. Try unit="Length"
      Valid strings for units are seen in "units>unit systems" in column A from the project schematic workbench page.
    • mjmiddle
      Also, the default usually has a quantity:
      default="0.0 [m]"
      • Azmin Zamsanirani
        Thank you, It is currently functioning; however, the coordinates' initial values after evaluation will consistently be in inches ("in"). The problem arises when opening ANSYS Mechanical with the unit system set to another unit. For example, if your current unit is set to "meters," and you evaluate a coordinate that is originally in inches (e.g., 0.2 inches), the software might display it as "0.2 m," which is meters. The only way to make it work as it should currently is to set the units in inches before evaluating the result.
    • mjmiddle
    • mjmiddle
      When your python code sets the value, you have to get the current unit and convert:
          import units
          #toUnit = ExtAPI.DataModel.CurrentUnitFromQuantityName(“Length”)
          toUnit = result.Properties[“MyProperty”].GetCurrentUnit()    # assuming unit=”Length” in property in XML
          fromUnit = ‘m'
          result.Properties[“MyProperty”].Value = units.ConvertUnit(2.54, fromUnit, toUnit)
      • Azmin Zamsanirani
        Thank you so much. It is now working after some modification I did but may I know where does units library and GetCurrentUnit() come from? Because I cant find both of it from global python documentation nor the ANSYS API and XML reference.
    • mjmiddle
      The units module is in the Ansys installation at:
      ANSYS Inc\v{version}\Addins\ACT\libraries\Mechanical\units.py
      It is dicussed in the Ansys online documentation (https://ansyshelp.ansys.com/):
      "Customization Suite > ACT Developer's Guide > Extensions > Libraries and Advanced Programming > Function Libraries"
      Example at:
      "Mechanical Application > Scripting in Mechanical Guide > Scripting Examples > Script Examples for Interacting with Tree Objects > Transform Coordinate Systems (with Math)"
      You can use the basic python command dir() with an object inside the parentheses to see the objects underneath it. So with some exploration you could find the GetCurrentUnit() under the property.
Viewing 5 reply threads
