September 27, 2017 at 11:19 am
admin
Ansys EmployeeIn ANSYS Meshing, Named Selections can be used to select or filter a set of geometric entities, like edges or faces, by using a criterion like size, type, or location. Please follow these steps to create a worksheet driven Named Selection: 1.Select geometry (e.g. edge or surface) 2.Right-Click > Create Named Selection. 3.Activate "Apply geometry items of same:" and select one of the 5 types (Size, Type, Location x, Location y, Location z). Note: This selection can be changed later, so feel free to select any one of the available checkboxes. 4.Press OK. In the Tree, select the Named Selection and a Worksheet will appear. In the Worksheet, the desired criteria for automatic selection of other geometry entities can now be defined by choosing an Action, Criterion, Operator, and Value.
admin
Ansys EmployeeActivate Criterion Based Selection in ANSYS Meshing
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
