August 27, 2018 at 8:00 pm
saivignesh786
SubscriberHi
When I use this designmodeller for creating geometry in ANSYS WORKBENCH >> FLUENT >> GEOMETRY>> New DesignModeller,the interface is opening but I cant use Create Menu.
Under the Create >> Primitives >> All options are greyed out in addition to many other options.
What should I do to activate it ?
Thanks in advance
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2614
2088
1321
1108
459
