Discovery Import
Discovery Import
Activation Failed
    • kha
      When activating an error occurred:
      ERROR: Unable to activate entitlement with activation id "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", error:
      FNE Activation Failed: FlexNet Embedded Action: FNE Generate Binary Request->FNE Send Binary Message
      FlexNet Embedded error: [1,7e1,8,0[74000008,0,110001f3]] Generic communications error.
      [1,7e1,8,0[75000005,0,3001024b]] An HTTP error was returned from the server. HTTP response code said error (0)
      What can I do?
      Regards, Khac
    • Gaurav Sharma
      Ha
      Can you please try to activate the subscription using the command lines as described here. I hope it helps.
      Gaurav
