Discovery Import
Discovery Import
Activation via proxy server
    • miyado
      Can Discovery be activated via proxy server?
      If possible, how to set up?
    • Brian Bueno
      Hello Miyado,
      I will consult with the licensing team to see if this is possible.
      • Brian Bueno
        In order to activate Discovery products when using a firewall or proxy server, open port 443 and clear the connection to https://ansys-fno.flexnetoperations.com/
    • miyado
      Is it possible to specify a proxy server inside Discovery?
      Or can Discovery refer to the proxy settings of IE?
