April 26, 2022 at 1:16 pm
k1739282
SubscriberHi
I would like a tutorial showing the implementation of an actuator disk as a simplified engine. This engine position is not critical as long as it shows the interaction with the body of the aircraft. I believe that a 2D simulation is sufficient enough to understand how ANSYS actuator disk works. The data obtained can be thrust or power used to propel the aircraft.
I suggest hypothetical conditions of 10m/s inlet air velocity and a 200 pascal of constant pressure jump across the line representing the actuator disk.
Thanks
April 28, 2022 at 4:39 pmRK
Ansys EmployeeHello,
Please refer to the Fluent's Virtual Blade model : 36.1. Introduction (ansys.com)
Here is a validation example : 36.9. Validation Examples (ansys.com)
This is Ansys Fluent 2022R1 and these are beta features.
May 16, 2022 at 1:33 pmgzilo1995
SubscriberHello,
i would like to ask if i can have access to VBM files as a master student. I am using the student version and i do not have access to the customers portal. Thank you in advance.
May 16, 2022 at 4:01 pmRob
Forum ModeratorThe links should open if you launch Help from within the solver first.
April 18, 2023 at 7:16 pmTighernan Shaffrey
SubscriberI am also trying to do this. I can not find any information on it. Can you advise me
Viewing 4 reply threads- The topic ‘Actuator Disk Simulations’ is closed to new replies.
Trending discussions- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1688
1478
