Actuator Line Model for wind turbines
    • Waleed Ahmed
      I want to model a wind turbine using an actuator line model. Can you guide me on how it can be done in Ansys? I'm aware of actuator disk modelling, but for my master thesis, I need to use the actuator line model.
      Thank you.
      What's the difference between the two approaches?
    • Waleed Ahmed
      In actuator line model, we consider blades of a turbine as line and apply lift and drag as source terms on the points.
      OK, so rather than a disk you need some rows of cells. You'll need to look at source term UDFs, and then how to map the line onto the Fluent 2d/3d mesh.
    • Waleed Ahmed
      Yes, that's what's I need help with. How to do it?
      I'd start with the UDF Manual. There's a reason we include some models for you to use: if you need something else it may need to be added.
Viewing 5 reply threads
