ADAPT REGION
    • Chitalu
      I've been trying to run the dynamic mesh simulation on Ansys academic 2019 R1. However when I went to set up in the work bench to access domain>mark adapt cells>Region I could not find, mark adapt cells>Region in the bar. I can only see the one shown in the image with a pointer. Cand someone show me where I can find the command, adapt cells>Region?
      Click on Refine/Coarsen and then "Registers" in that panel.  The interface changed at 2019 so have a look through the options.
    • Chitalu
      Thank you! It works.
    • nepomnyi
      At least for me this advise didn't work. Or I don't know where to look at. I use FLUENT 2019R2. What I ended up doing is running "Help" . It is said there that the option is removed from the ribbon and needs to be switched on from TUI.
      So, if anybody else faces the same problem, then go to TUI (command line) and type: /mesh/adapt/ revert-to-R19.2-adaption-user-interface
      Important note: this won't work. At least you will see the error that the command is invalid. Don't trust it. Have a look at the ribbon - the option should appear there. If not, type the command a couple of more times. Personally, I noticed that the option was already in the ribbon after about 7 attempts to run the command.
    • Joe001
      > Refine/Coarsen > Cell Registers>New>Regionn
      Thanks ArraynTo add to the thread, the TUI command may have unintended side effects as we move into 2020Rx and newer releases. Also Anisotropic adaption is now done via the newer menus, do not use the option under More as it's been superseded.
Viewing 5 reply threads
