Tagged: #multiphase_models, patching, region-adaptation
January 5, 2023 at 5:37 pm
Hilary Egglestone
Subscriber -
January 6, 2023 at 5:07 am
SRP
SubscriberHi,
I suggest you to refer to this tutorial: Chapter 24: Using the Eulerian Granular Multiphase Model with Heat Transfer (ansys.com)
If you are not able to access the link, please refer to this forum discussion: Using Help with links (ansys.com)
Thank you
January 6, 2023 at 10:32 am
Ansys EmployeeOdd, can you confirm you initialised, then patched? In 2d you shouldn't need to select any surfaces in the Contour panel, if Fluent picks anything then let it!
January 6, 2023 at 7:43 pm
Hilary Egglestone
SubscriberSRP - thank you for the resources.
Rob - confirmed! It is initialized first, then patched. Then, I went into the contour graphic settings and hit "display" to ensure it was displaying the latest information. Any ideas?
January 9, 2023 at 7:18 am
Prashanth
Ansys EmployeeYou can also try initializing and patching the region without Patch reconstructed interface setting. It might not be suitable for patching certain regions.
January 9, 2023 at 9:46 am
Ansys EmployeeHow many phases are there?
January 10, 2023 at 12:31 pm
DrAmine
Ansys EmployeeCheck if for the region the extents are well defined say starting point coordinates are < end point coordinates. That is required for reconstructed patching. Does it work without reconstructed patching?
2620
2098
1323
1110
461
