March 18, 2021 at 11:29 am
michutorres
SubscriberHi all,nI made a fixed time step to get the convergence with time step =0.01 and 25 iterations per step. Then someone recommend me to use adaptive time step to let the software decide. How can I do this? It is inviable to continue with ime step =0.01 and 25 iterations per step as I need to simulate 30 minutes (1800 seconds) of real life.nThank youn -
March 18, 2021 at 12:19 pm
Karthik R
AdministratorHi, nIn the run calculation, change the Time Advancement type from Fixed to Adaptive. This should enable Adaptive time step. The default is CFL-Based. If you wish to read more into this, please use this Users Guide link below.nKarthikn -
March 18, 2021 at 1:32 pm
March 18, 2021 at 2:22 pm
ai0013
SubscriberIt depends on your flow characteristics. nTypically an accurate solution requires a CFL = 1 (For explicit treatment). This will assure that your flow doesn't travel more than one cell per time step. However in implicit treatment, people often can raise this number to 5-20 (or even higher) at the expense of loss in accuracy. If you can afford running this condition, it will be optimal, nIf you do LES you should decrease this number to 0.5 (or even lower)nn -
March 18, 2021 at 2:30 pm
michutorres
SubscriberWhere can I set the CFL=1? Is this the Courant Number?. -
March 18, 2021 at 2:48 pm
DrAmine
Ansys EmployeeThat is the Global Courant Number calculated in the interfacial cells. For implicit runs you can try have it lower than 5-20.n -
March 18, 2021 at 2:59 pm
March 18, 2021 at 3:02 pm
DrAmine
Ansys EmployeeIt will adapt it based on the adatipve method used and whether you are running multiphase or not.nFor single phase we have at least two way: truncation error based and CFL based. For the user friendly CFL based, Fluent will try to update the time steps based on your settings to increase the time step size or reduce it so that CFL criterion is matched as much as possible.nnYour description is correct. n -
March 18, 2021 at 3:13 pm
michutorres
SubscriberI didn't enable multiphase model. nI enabled solidification&melting, viscous laminar and energy on.nI have a single phase. I am using CFL.nSomeone from this forum told me that firstly I need to get the convergence with fixed step and then turn to adaptive step. But then I don't know if between this change I should initilize and set the adaptive step as in the fixed method or I should continue with the calculation without initilizing another time.nn -
March 18, 2021 at 4:15 pm
DrAmine
Ansys EmployeeYou can restart with clean initialization and use that adaptive time stepping. I usually do not use it for single phase runs but that is a personal preference. It is not bad.n -
March 18, 2021 at 4:28 pm
michutorres
SubscriberI am running the simulation and I think now it's ok and in few hours I could have the simulation finished.nnNow the temperatures of the internal faces of the deposit are increasing correctly. But the problem now is that the temperature of a point in the adhesive is not increasing correctly. I checked the properties of my adhesive and are ok. Maybe there is a problem with the interface between the deposit and the adhesive, or maybe it's a problem with the physics of Fluent... What do you think?n
March 18, 2021 at 4:33 pm
DrAmine
Ansys EmployeeYou can check the heat balance at that interface if it is physical + double checking material properties + check your mesh quality and consider convergence every time step. I am sure that Fluent can handle this kind of problems in very accurate way.n -
March 18, 2021 at 4:36 pm
michutorres
Subscriberok. How can I check the heat balance at that interface? That has to be checked at the end of the simulation or I can print to console like residuals?nBy the way, I won't be capable to interpret if the heat balance in that itnerface is correct or not.n -
March 18, 2021 at 7:01 pm
DrAmine
Ansys EmployeeAs flux report or as Report definition.n -
March 18, 2021 at 9:47 pm
michutorres
SubscriberMy heat flux is 79000 W/m2. Now that I am going to check the heat balance at the interface between the deposit and adhesive making a report definition, which should be the heat interface value?n -
March 19, 2021 at 12:40 pm
Karthik R
AdministratorHi,nWhat means is - please check if you are conserving your total heat. Check if the energy is conserved. If it is not, then your solution is not correct and you will need to properly converge your model.nKarthikn -
March 20, 2021 at 8:21 am
michutorres
SubscriberHi,nnow I am going to refine my mesh as someone told me that mesh quality skewness should be under 0.8 and orthogonality mesh quality should be higher than at least 0.15.nI clicked on Metrics Display and I can only see a graphic like below. Where can I check the exact value to see if my skewness is under 0.8 and orthogonality over 0.15?nn
March 22, 2021 at 10:35 am
DrAmine
Ansys EmployeeYou can limit the graph and then click on the pivot / pillar to highlight the cells. However I recommend doing that in Fluent and rely on Fluent metrics.n -
March 22, 2021 at 10:41 am
michutorres
SubscriberHow can I do this in Fluent? Where is the option Fluent metrics?n -
March 22, 2021 at 11:49 am
Karthik R
AdministratorHi,nYou won't get a histogram plot like this in Fluent (not unless you are using Fluent Meshing). If you are working with Ansys Meshing, it is better you do this there. In Fluent, you will only be able to print the values of your mesh quality or plot a contour of your mesh metric. Look under Contour -> Mesh -> Orthogonal Quality and see if this helps.nKarthikn -
March 22, 2021 at 2:48 pm
DrAmine
Ansys EmployeeIn Fluent you rely on iso-surface or cell registers to show the cell with certain quality range. No histogram like in Ansys Meshing.n
Viewing 20 reply threads
Trending discussions
Top Contributors
2524
2064
1279
1096
456
Top Rated Tags
