March 1, 2022 at 10:24 pm
goldenalcheese
SubscriberHi, I am using Lumerical Interconnect. When I add a component from the built-in library by double-clicking it. Multiple components are added on the schematic. Any clues?
For instance, in the attached screenshot, I want to add one coupler into the compound. But after I click the icon, 22 couplers are added ...
March 2, 2022 at 7:41 pmKyle
I've replicated this issue myself, this appears to be a bug. I'll report this to the development team. Thank you for bringing this to our attention.
As a workaround for now, it looks like adding components by clicking and dragging from the Element Library onto the schematic view still works properly. The script command addelement seems to work as well.
- Error on Lumerical device
2656
2120
1349
1118
461
