Photonics
Photonics
Add rough surface to a hole cavity
    • ur21581
      Adding the Rough surface generated with sroughness to 3D hole produced picture 1.
      The roughness was added in z-direction...
      However, I actually need the roughness to wrap around the hole, like picture 2.
      Please help! Thanks.
    • Guilin Sun
      In the object library, there is an example of rough rod surface:
      There are also groups with roughness, such as
      You will need to first understand how do they work using script, and then modify them to fit your needs.
      • ur21581
        HI Guilin,
        Many thanks for the helpful reply!
        I shall look into these functionalities further..
    • ur21581
      HI Guilin,
      I shall look into these functionalities further...
