April 13, 2022 at 7:39 am
gideonappiah
SubscriberHello,
I have problem displaying the "add winging" window for Maxwell transient. Is this a bug?
April 13, 2022 at 11:24 amNavya C
Ansys EmployeeHi @gideonappiah This could be due to your PC display settings(screen resolution).
If not please share which version of Ansys are you using?
Do you face this issue with any other popup/ property windows?
Regards Navya
- Maxwell, HFSS or Q3D?
- Error
2524
2066
1279
1096
457
