Materials
Materials
Adding a new Hyperelastic material in ANSYS Workbench Library.
    • Abdulsalam
      I want to add PDMS Slygrd 184 in my ANSYS workbench Material library manually. What are the main properties of the material I need to add so that when I perform various analysis on ANSYS than I can get the correct results and compare it with my experimental result . I have the experimental result of uniaxial test can I use it and then use any of the hyperelastic models like Ogden model. Will this be enough or do i need to go for more properties. If i need to look more properties than which are those? Is using the hyperelastic models only is enough to define my PDMS Slygrd 184 properties ?
      I have attached a photo  of my work for your reference. please I need your help As soon as possible
        Thanks In Advance
Viewing 0 reply threads
