Adding Darcy’s Law( Cozney-Carman) expression as a source term in momentum equation
    • waqas12345
      Hello all.
      I am new to simulating the laser welding process using Ansys fluent. In the momentum equation, cozney-Carman expression is added as source term on the right hand side of the equation. May I please know that is there any way that I could write this source term using an " Expression" function" ?
      The image of expression is also attached where fL is a liquid fraction, v is a velocity and rest are all constants.
      Any help shall be highly appreciated.
      Thank you in advance.
    • DrAmine
      Better to do that per UDF so that you can add coefficient of linearization. UDF manual has an example how to add source terms into the Momentum equations.
