June 8, 2023 at 1:22 pm
satri
SubscriberIs there a tui command to add a particular material in fluent from the GRANTA MDS database?
June 8, 2023 at 2:37 pm
Ansys EmployeeDirect from MDS, probably not. If you have the licences for the Fluent Granta MDS database it should be possible to switch database and then copy a specific material over.
June 8, 2023 at 4:52 pm
June 8, 2023 at 5:11 pm
Ansys EmployeeTry in
/define/materials/data-base database
and go from there.
June 9, 2023 at 12:07 pm
June 9, 2023 at 12:29 pm
Ansys EmployeeOdd, does it show in the GUI panel?
June 9, 2023 at 12:33 pm
June 9, 2023 at 1:27 pm
Ansys EmployeeIf you can copy from the GUI it should be available in the TUI, unless you're using an older version and it's a recent addition to the TUI. Are you using the same version, computer and session for both TUI and GUI checks?
June 9, 2023 at 1:41 pm
satri
Subscriberyes, i have only one version of Ansys installed on the computer 2021 R2.
please let me know which version of Ansys supports this command.
June 9, 2023 at 2:04 pm
Ansys EmployeeIt's there in 23R1, and not on 21R1 here either. I think that was the first release so quite possible the TUI menu wasn't added immediately.
7592
4440
2953
1427
1322
