March 12, 2023 at 2:32 pm
fares abbara
SubscriberI have an elastic tube that i would like to add certain material properties to it, taken from literature. The tube is assumed to be hyper elastic with tabulated stress-strain data. The stress-strain graph is non-linear, but it was assumed to have to linear parts with different Young's Moduli. I am testing the model on transient by applying a cyclic loading, however, i need to add density and Young's modulus readings. The density part if covered, but i don't know how to go about the Young's modulus specification given that i have two different moduli (before and after a certain strain reading on the graph). the material is also assumed to be anisotropic.
March 12, 2023 at 4:49 pm
Subscriber-
March 12, 2023 at 5:15 pm
fares abbara
March 12, 2023 at 7:12 pm
SubscriberThe negative slope is problematic. That will lead to instabilities during the solution.
I suggest you discard the stress-strain data below a strain value of 0.03 and fit a lower order curve to the remaining points. That should eliminate the negative slope.
March 21, 2023 at 5:25 pm
fares abbara
SubscriberThank you for your suggestion, Sir.
I have done as you said and the model ran smoothly. However, i have ran into an issue when probing stress and acceleration in the solution. I created 4 coordinates (2 on the outer surface and 2 on the inner surface of the tube), and i assigned those coordinates to the probes accordingly. However, while the probes on the outer surface displayed results, the inner probes do not seem to be generating results. i tried several times to update the solution, but to no avail. I attached a screenshot to show the positions of the coordinates and the solution section. As you can see CTP and CTP_2 probes are showing results while CSP and CSP_2 are not.
March 21, 2023 at 11:13 pm
SubscriberSlice the geometry to create a vertex at the location of the coordinate systems. The vertex will move with the elements as they change shape while the coordinate system stays in place while the elements move away from that point.
3744
2570
1787
1236
594
