March 19, 2021 at 5:01 pm
tgartner
SubscriberHello,
I am wanting to model Sapphire in Lumerical but i see it is not in the materials database. Is there a way I can add it via its dispersion (sellemer) formula as follows:
March 19, 2021 at 8:07 pmKyle
Ansys EmployeeHello Array,nYou can create a customer material with the Sellmeier model by adding it to the Material Database. This page has more information:nArrayThe materials in the material database can be modified with the setmaterial script command:nArrayAnd you can set the materials of objects in the simulation with the set command:nArrayLet me know if you have any questions.nViewing 1 reply thread- You must be logged in to reply to this topic.
- Error on Lumerical device
2726
2146
1357
1150
462
