October 10, 2018 at 2:30 pm
Omid
SubscriberI am using magnetostatic analysis to simulate permanent magnets. I would like to see the magnetic field and flux density between two bar magnets.
The problem is that Neodymium is not in the library (using v.19.1). I checked some of tutorials and it was clearly there. Does anyone have any idea why it is eliminated?
And how can I add it to the library. Does anyone have the required specifications?
October 17, 2018 at 9:18 pm
- Maxwell, HFSS or Q3D?
- Error
2630
2104
1327
1110
461
