Adding new material in fluent
    • Samiksha
      I was trying to add new material ( iron ore) via user based database in fluent but it is showing material already exists. I checked this material in existing database but couldn't found and also not able to add new material.
      The material already exists or the database already exists? Do NOT try and edit the Fluent database, and make sure the user database has a unique label.  The two most common causes for "already exists" are that you've copied a material over already or you've used a chemical formula that's already present.
