April 22, 2023 at 1:52 am
Aravinth Ekamparam
SubscriberIs there any way to add points to the surface using .csv file? This means I want to add 100 points to the domain. It is hard to add every point manually. I am looking for an alternate option to create points on the domain.
April 24, 2023 at 8:47 am
Ansys EmployeeFor monitors? You can adapt the csv file into a journal. The only issue with points on a surface if rounding error: chances are some points are going to miss the domain.
5162
3251
2443
