TAGGED: battery-modeling, modules, msmd-battery-model, ntgk-model
June 30, 2022 at 11:58 am
ali.abbas
SubscriberHello everyone,
I am modeling a battery module composed of 3 cells, at first i designed 3 cells and with the MSMD submodel NTGK i found that the 3 cells have same results which is not logical ( the cell in the middle must be more heated)
A second trial i designed solid bodies which are directly connected to the cells and i assumed that these bodies are fluid regions and as a result i see the cell in the middle is more heated (logical result).
Can anyone explain to me how ansys fluent is modeling the fluid regions (gap between the cells), i am trying to develop an analytical model for the module and always stuck with the gaps between the cells how to model them
July 25, 2022 at 3:45 pm
RK
Ansys EmployeeHello,
For the first trail, I would suggest to re-check the simulation and the settings to make sure they are right. You can follow one of our tutorials for best practices.
July 25, 2022 at 3:47 pm
RK
Ansys EmployeeFor information on the modeling, please refer to the Ansys Fluent theory guide.
3930
2649
1863
1272
610
