April 26, 2023 at 10:35 pm
anna
SubscriberHi, sorry if this is a silly question as I am quite new to ANSYS but I want to simulate a robot arm in ANSYS rigid dynamics in order to calculate its energy consumption, and i've added rotation joint loads in order to make the robot joints bend. If I want to find out how the energy differs as I change the velocity, how exactly do I define the velocity of the robot in Rigid Dynamics as I don't see an option to do this? For example if I want the robot to move at 1m/s how do I do this?
April 27, 2023 at 3:03 am
Sampat Kumar
Ansys EmployeeHi Anna,
you should follow the following process
create a translational joint body to body(right-click on the joint in the connection tree then select translational in the ” type”) -> select the joint load in the transient -> select the velocity.
For more information, you can follow the attached link- 2.3. Connecting Multibody Components with Joint Elements (ansys.com)
All the best!https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest
3325
2471
